What is Tiger Seal ? , Tiger Seal is
Would tigerseal seal my fuel filler pipe? I have a tiny hole in it which petrol has been seeping from. I think I have more or less sealed it with white bathroom seal, is this similar stuff?
ive had this on my hands multiple times, it sucks
you can always use plastic gloves to save time ;)
If it peels off it's because you've not thoroughly degreased/abraded the surfaces you need to stick together. Acetone or Spirit/Panel Wipe for degreasing, not white spirit (which is greasy!). Ideally, painted surfaces should be taken back to the bare metal.
This is very good advice above
we use tiger sealer to put new panels on buses if its done right they will not come off
we use vibrating air knives to remove damaged /old panels
Windscreen sealer/ glue is different to panel glue
for windscreens the window and frame has to be cleaned with spirit and then primed with special primer first
this is with 45 years experience :eek: (y)
Graham
heh i was actually under the car today checking the condition of all the rubber boots on the prop shaft and making sure it was all greased up.. (ready for the potential snow)
happy to report that the prop is still held in place super securely with no cracking on the tiger seal :D
