Thank you so much you are a star xxx
Thanks again. I've got all the measurements but am really struggling to get what I need. The standard for a 12 mm bolt/threaded rod is 1.75 and the one I need is 1.25so I need 12 x 1.25 x 100 with 30mm thread on each end. I will not give up though. I've got 12 mm bolts but they are standard thread, I have access to tap/die set but not sure if you can make that change. I have contacted a few places asking for help just waiting on responses.
I'm in the process of asking around. Thanks again for all the help.
Just a thought, I have access to tap and die set could I get it done using that? Would that work?
I'm in St Helens in Merseyside
This is the actual piece, and it's that bit sticking out the top that snapped and it's threaded both ends.
If you can't have a part made then might be worth asking some of the ones being broken on eBAY how much for the bracket complete. Then you can swap them over while you get yours fixed as a spare:
http://www.ebay.co.uk/sch/i.html?_f...0.H0.TRS0&_nkw=Doblo+1.9JTD+breaking&_sacat=0
