Technical What is this part called? It holds 10mm bolts on the engine cover.
OneHundredPandas
England
I was removing my engine cover, and I had to remove 3 10mm bolts, but I lost 1 of the 3 things below in the process. I have asked around and don't know what this part is so I cannot replace it. Any ideas?
Looks like part of the airbox
I don't think fiat ever supplied them seperately
Might be the same as some other fiat models, fairly sure the other petrol panda ones would swap over
I think I have seen some new third party ones for the 500 somewhere
Head to the scrap yard to see if a similar Fiat model is there to rob parts from.
You may be able to use a rivet nut in its place if you find an appropriately sized one. You’ll just be using it as a nut rather than drawing it in to be secure like a rivet.
Other options may be a socket joint nut, or poss a cylindrical jack nut, if the right thing can’t be found.
I feel your pain.. 🙂
We "somehow" Lost a glow plug in a similar fashion... And nobody stocked them.. 😭
So we spent 2 hours with a mirror.. And found it on the rear of the motor🙄 sat in a void
So what Panda is this..?
I recognise the type of 'washer'... am also thinking "airbox".. or other plastic moulding..
Were the other 3 also 'loose' ?
I see you had asked, for a100HP
"how do I remove the engine cover"
Plenty on here have tinkered with old HP's.... doing intake mods etc
Somebody will have an unused one lying around
I will check the engine cover I have sat in a shed (from a Diesel..). Probably identical hardware on them...
Where are you based?
Looked quite hard and couldn't find any
It's part of the airbox and not shown as a seperate part
Third party rubber such as these are available on ebay and it's likes
I have never tried one but 1.2 fiat 500 looks very similar, here a shot from the underside of a 500, breakers might be the easiest
This guy has a 100% feed back, might be worth messaging him with some photos
I'm not sure someone breaking a car is going to want to start pulling individual small parts like this off some bigger part like an air box for the few pennies they could make selling them to you, to the determent of a whole air box that is worth a few quid.
I'd be inclined to do as Bugsymike says above and look at just getting a similar diameter piece of metal tube from a hobby shop or online and cutting it to length.
The actual description for something like this is a "Flanged Bushing Sleeve" so whack that into Ebay and see what you come up with.
