This is a question out of curiosity since I'm getting an amp that can handle it anyway, but...
I have a set of twin 12" subs in a sealed cabinet that are wired in a 2-ohm configuration. Just switched from a single 12" sub at 4 ohms. The amp I'm running them off is a cheap eBay jobby (shoot me, I know) that has 6 channels and claims 1000w for the sub. No sign of "RMS" so I'd say "more like 50, pfft" except it HAS proven incredibly powerful and more than thrashes a 600w kenwood I was previously using to drive my bass.
So these new subs are happily tearing my car to shreds but if I REALLY crank it - and we're talking up to the head unit's limits - then on some bass hits (often of higher frequency) the amp will cut out. It's also getting a damn-sight hotter than it ever used to. I'm assuming this is indicative of an amp that can't really handle a 2-ohm load as I'm checking the car's voltage and thanks to a beefier battery it isn't dropping below about 12 volts. I know this amp will run down to nearly ten from past experience (and crapper batteries, haha).
What do you make of this?
a monoblock is on the way to replace it since I never use 5 of the 6 channels (kenwood is dealing with the rest quite nicely) and this amp is mahoosive. Nothing has burst into flames yet, I will just keep it lower until the new amp arrives.
