BillyBong New member Joined Aug 16, 2019 Messages 2 Points 2 Aug 16, 2019 #1 doblo premio plus generic warning light, same one as in my avatar, it suddenly just came on after I jet washed my Doblo??
Eklipze3k No strings on me Staff member Parked in the garage Written a guide Joined Nov 18, 2007 Messages 18,438 Points 4,435 Location Huddersfield Aug 17, 2019 #2 Assuming it's not accompanied by an error message, you'll need to get the codes read as there are tens of reasons that this light could come on. Suffice to say, the ECU is seeing an error from at least one sensor.
s130 Moderator Staff member Parked in the garage Written a guide Uploaded a resource/download Written a review Joined Dec 5, 2006 Messages 6,372 Points 1,641 Location Wrexham, North Wales Aug 17, 2019 #3 Looking at a 2015 Doblo manual then causes are: Engine oil pressure sensor failure Lights failure - rear fog, side, daylight running etc Fuel cut-off system failure Parking sensors Start/stop system failure If it flashes then the airbag warning light has failed You can check the operation of these yourself. As you jet washed the car then the lights are a good candidate.
