Technical What could be causing this leak?
tomfoster
Further to my thread yesterday about brake fluid loss, this morning I jacked the car up and had a look underneath. There was a giveaway wet patch under the rear of the car, and sticky fluid on the underside of what looked to me like the fuel tank? Here's a couple of pictures:
It seems a strange place for brake fluid loss and I can't see where it's coming from. Can anyone help?!
Hi
On your second photo tie wrapped onto the beam you can see the brake pipe going across. Directly above where the drip appears on the floor is a union in the pipe. Is this tight ?
Danny
That looks like oil leaking out of the sump tank (probably the sump plug is the cause)
As said above, this is at the back of the car. I replaced the sump some time ago and thankfully that's not the problem!
I will go and check once the snow stops! There is a large wet patch on the bottom of the fuel tank, so it seems as though the fluid may be dripping from above the tank, then running down it - is there a brake pipe that runs above it?
Yesterday the brake fluid reservoir looked pretty much empty, but no warning light came on on the dash - is this normal? I'd have thought an ABS-equipped car would have given some warning of there being no fluid left?!
mark one punto`s have brake pipes running over the tank and there was a recall for them to be checked because they were rotting if you live near stoke on trent pm me cheers carl
Well, I got this sorted out in the end, and it was indeed one of the brake pipes that run down the centre of the car from front to rear, it was badly corroded. I rang Fiat about the recall, and my car was apparently done in 2003, so they only lasted about 5 years! Also, the fuel tank did have to come out in order to get at them. Plus, the extremely rusty bleed nipples on the rear brakes are now completely buggered! I hate working on these rusty old cars...
The car still failed its MOT afterward though - a dodgy track rod end, and excessive corrosion around one of the jacking points. I've done the TRE, but am going to have to go to a mechanic about the corrosion, as I don't know the first thing about welding :-(
