General What are these?
It's not unusual for wires to be missing from the fuse box,
It's normally easier just to install a separate fused spur for power
Plenty of info on here if you search for cigarette lighter as most of the active range stops short at the a pillar, there's a couple of spare grommets in the fire wall with nothing in them
Yep the fuse to the side of the obd connector
And fuses in the body computer itself
So it looks like the wire goes from F85 to BCM and then BCM to Pin2 on the subwoofer connector.
And as the car didn't come from the factory. With the so called Rip off Woofer pack! The BCM dosent allow the power output. Now if that's not a Monopoly control. I duno what is.
Yes i could run a wire from another point. But now im going to get the laptop talking to the BCM.
What a complete FAFF! No wonder fitters scratch there head's these days!?
No
Goes from the fuse box to a coupling to the sub
Body computer not involved in the sub
Dash coupling
Pin 12
Always double check
Fiat don't use unique colours
And changes from model, year, engine euro version, lots changed around 2008 and so on
Dash coupling
Pin 12
Always double check
I really appricieate your help so i tried to find the info you posted i got this.
Which says fuse 54 is Subwoofer next to ODBII sensor? :unsure:
LOL so i traced it physically. Goes to a black connector in passenger foot well!? That's your dash coupling i take it.
Ive proved this with a continuity tester as well!
There is no wire on the otherside of the plug so it seems F85 dosent have a wire to this connector? Jee's what a pullaver.
or i could pinch it from cigar lighter.
Yes
Normal
Excellent
Cigarette lighter is good for 20A I believe, might double check if you decide to go this route, fiat wires normally have plenty of headroom, but their connector suffer with oxidation
The original sub had a separate fuse of 10A on the side,
Guess it all depends what you are going to install and if it's separately fused 100W with a 10A fuse sounds (joke intended) about right, but I.C.E isn't my sort of thing, there is a separate section on here
Yes
Normal
Excellent
Yeah there's a seperate 10 Amp on the side. I suggested the cigar or cigarette lighter depending wether your POSH or not!? :censored: As an easy way out. Running a cable through the bulkhead and then trying to put some sorta spade connector behind the engine Fuse box might be more hassle then it's worth! :whistle:
12v 100w is 8.3 amps. Thats probably why the sub has a 10 built in for Discrimo!
