General What are these?
Baggey
Kernow
So little quiz. How well you know your pandar.
Clue it's on NSR arch.
what is this thingy?
It's under passenger seat RHD. and whats the connector for?
My guess is some sort of sensor to know car hasn't rolled over and cuts stuff of?
I have a Subwoofer unit and this plug matches but no BOOM BOOM!
This is under the Drivers seat RHD
Next i have two Abarth 500 seats with these plugs
Do i have the facility to have Winter BUM warmers?
Little bit of fun but im also being dead serious, as i have no workshop manual that is as good as a Haynes Manual! :rolleyes:
Kind Regards Baggey
Two looks like the slew sensor, have to see see the wire colours to be sure, only used on cars with esp
Could you please educate me! I could Google. But value your insight 🤗 I can get detailed colors if needed.
Not sure about the connector in picture 2 but is the "thingy" you asked about the fuel cutoff switch?
Picture 1 - Earth blocks are dotted about the Panda Theres another under the windscreen scuttle.
Not sure about picture 3, as I can't identify the connector from the picture (pins not visible)
Pics 4 &5 Would have expected those connectors to be for the seat airbags, but they don't look the same as the ones on my Arbarth seats.
Electronic Stability Programme
Sensor reads yaw and g force and is combined with steering angle sensor
Then automatically apply brakes individual wheels via ABS and controls the throttle, to regain control in a slide
Black is probably seat occupancy as the divers seat normally doesn't have one, and I guess the other maybe the seat belt, not all arbath seats are wired the same, some don't have airbags for example, your best asking on the 500 section
Me and the misses were getting exited when we thought we may have Winter BUM warmers. 🤗
Ill get better pics of the connectors. As i would like to know the pin outs. Especially for the Boom Boom box!
Would be nice to get hold of a good wiring diagram for the 100hp.
Theres another silver box mounted on the tunnel right by the steering rack where it comes into the footwell.
Airbag sensor
Awesome! I can bell out some wires now! Me thinks there was a plug with some wires behind the old radio. :cool:
The sound system at the mo in the car is a Pioneer Double din Head unit and E-Type alpines all round but it sounds :poop:. It had the white screen of death but just needed reworking with the solder station. To bring it back to life!
If i cant get an improvement i may try an android unit running Lynux and AIMP BLACK ONYZ. I have a set off logitek 5.1 Speakers. That would sound well nice. Ive stuck layers of sound insulation on everything.
To be fair
They seem more reliable than stacking multi ring eyelets onto one stud
Probably just quicker in manufacturing, and harder to mess up
That's what im used to seeing stacked rings. Or on the VW they use an earth dognut type disc under steering column.
Is this something i could retro fit or does the ECU need programming for it?
Here are some better pics
All i got todo now is relate these to Kolars diagram and jobs a BOOM! BOOM! ;)
Yes, no, maybe
It will need the correct ABS module as well
The yaw or slew senor which ever you like to call it
Only has six connectors
Power, ground, canbus H X2 canbus low X2
So if you plug it in and do a proxi align the body computer should recognise it and add it
Two pins on the abs module are used to switch ESP off, I suspect missing these wires the EPS will just be permanently on, I don't know I have never tried myself
Someone on here is fitting an engine and ABS module with ESP from a 100hp it was an option into a 4x4 but the results aren't in yet
Yes, no, maybe
So if you plug it in and do a proxi align the body computer should recognise it and add it.
Is the body computer the blue thingy behind glove box?
Interesting. Ill get a better picture of the connector for pinouts and colors.
The Red and white wire according to the diagrams go's to the fusebox in the engine compartement. F82 which dosent have a fuse in it. 3rd one up. It dosent look like theres wiring behind it either. I plugged a 20amp in but no supply to the amp pin2? Ive found another fuse box in behind the OBDII plug which seems to be installed in a way your not supposed to get at it.
What is this box.
I dont really want to trace the wire phisically when decent information would save me alot of FAFF!
ive proved all the other wires goto to the back of the head unit plugs.
Also struggling to find the type of fuse they are Ebay only showing mini blade and normal?
Its the big fuses sorta middle right im after
