What are these wheels
Hi all I have managed to get these for £25 set of four they are off a stilo but not sure if they are original as I am after 1 centre cap but need to know if they are genuine fiat alloys these are 16"
Looking at ePER I can see these blade wheels with part number 46796525 but they are listed as 17 inch wheels, not 16.
Centre Cap is P/N: 46746586 and cost £6.56 in July 2012.
AS ALWAYS DO NOT directly order by part number. Go to dealer and get them verify and order the part for you that way any error is their responsibility. As a last resort you can a) check they will take returned parts if they are wrong and what their handling chage is and then b) then take a chance :)
Finally have a look on the Fiat Forum's ePAR for yourself. You will be able to see all the available wheels etc. for yourself.
Just great fiat does not recognise the wheels let alone the centre cap now I am stuffed anyone have any other ideas where I can get a couple from ?
They can find what they think is the wheels despite me parking it right outside the door they had a look and said I think it may be these or it could be those, then they said oh I don't think that we do the centre caps for them do I just go for what has been posted on this forum 46811728 .?
Yes
these are defo stillo 17'' blades i've got these on my fiorino van,there getting quite rare now.
£25, you got yourself a billy bargain there.
Centre caps do come up on ebay every so often. just keep an eye out
I need to replace a retaining clip on one of mine,but if i come across a centre cap i'll pm you
LUIGI
Yes
LUIGI
There was a 16" version made in europe...
I suggest measuring the diametre of the wheel to be sure!
1st things 1st
Please check your wheel sizes/tyre sizes and post back.
Also check every part of the alloy wheels an note down EVERYTHING you can see. Check several wheels and both inside and outside, rim lips etc. etc.
You may indeed have 16" wheels as opposed to 17". With luck you may find an 8/9/10/n digit part number somewhere on the rims. All this will help.
Coming back to something somebody else commented on then hub / centre cap size is generally not affected by overall wheel size. The centre boss areas/sizes are generally standardised over a range of wheel sizes. This means that if you have 16"/17"/18" wheels then the hub caps/bosses are likely to be the same size.
Update guys I got call today from fiat they found the part number and had one in stock result but they charged my £15 for it
