hi my punto 04 starts first time but if its damp wont pull seems to take about 10 mins to settle down then it drives fine allday
thanks I will try to do this a.s.a.p
not you to!!!
this is a common fault have you sorted this and what engine 1.2 8v by any chance???
:slayer:
Would I be right in thinking this will be the exact same engine as the one used in a 2006 Panda? Although not had these issues (yet!)
yep the engine is, but don't know off the ecu as that's the main problamwhich I believes different worth checking. Fault on the puntos, makes them costly as if you don't it kills the fault you can blow the ecu
worth checking as the engines the same in a punto and panda and the block was origanlly in a cinq and you can still get the same block today with a VVT system like Hondas VTEC![]()
