Violetlexy
- Joined
- Dec 6, 2012
- Messages
- 5
- Points
- 2
A few days ago the headlights (both of them at the same time) began flickering when I start the car, then stopped and worked normally after a few minutes. I thought maybe it was because of the cold spell. It has been getting down to -20 degrees at night and we do not have a garage.
Two days ago, the lights stopped coming on at all. I checked all the fuses and everything is fine. I took it to a shop where they checked all the grounds and they are all fine too. They ran diagnostics and could not find a problem.
They started to check all the fuses again, and here is the weird part: when the fuse at spot 3 is removed, the headlights work again. Replace the fuse, and they stop working. Fuse #3 is for the Rear fog lights, Rear fog lights warning lights, and Side / taillight power. We also noticed that the rear licence plate lights also went out with fuse #3 removed. What the heck does this mean. Can anyone shed some light?
