weird??
weird??
G
GMAN
1) if i press down on the brake
my clock radio time fades a bit? weird ???
2) when i start the car from cold, its judders for about 10-15 seconds then idles as i expect it to? why is it doing this?
3) whem i start from cold, and rav i can hear the air gushing around, possible airlock but its difficult fr me to get out, if i open the coolant lid slowly , its always hisses
4) my temp gauge at times move about funny, up and down, its meant to be halfway, guess its faulty, expensive fix? worth doing?
5) My aerial i can now pull out, its meant to be a screw one? is my aerial faulty or the actual mount itself?
I have a fiat bravo 1.2 2001
i hope you can help
1) Check the rear light cluster earth
2) Sounds like old plugs or bad leads
3) Do a bleeding of the system and the lid will hiss because how the temp rises, the pressure rises also so doing that you equal the pressure in the cooling system and the outside.
And btw - do not remove the cap when the engine is hot, you may get burned.
4) If you can pull out the areal and see the thread on it or if its pulling any plastic bit of the base its broken - new base is needed.
All guides on these things can be found under the repair section of the site.
Members Site ---------My Site
NO ITS NOT!
lol
thansk sven
can you help with number 4 as you answered number 5
will check things over once this rain stops!
P
7
238
M
A
6
509
Anonymous
A
11
594
Carroll
C
J
4
351
J
R
4
131
M
