As you will know if you have read Idiot v's british weather, I have recently had my cambelt replaced on my 60SX.
I was told by the garage that they would check my water pump and replace if need be, however need be, and they still didn't bother. So I'm going to go for it myself, what with being keen to learn mechanics and also being tight fisted.
The question is, I know so much that I have to remove the cam belt and just unbolt the pump, gasket and re-fit new, everything back on and away, however the one thing I don't know and can't find out anywhere is:-
Would removing my cambelt, without moving the car in anyway at all, would it knock my timing out as that is something I'm not sure I could do?
Ricon
Ricon
