yellowbrick
- Joined
- Dec 1, 2016
- Messages
- 37
- Points
- 11
hello there,
I have just bought a cinquecento sporting abarth 1.1.
Everything seems to work well for couple of weeks, though yesterday the ac was blowing cold. The temp guage appeared normal, no overheating.
This was odd as i only topped up the water the week before.
I stopped soon as i could, put water in, the water seemed to have gone down more than it should, was about 2/3rds full but seemed enough for a/c to work.
I topped up water anyway and then a/c worked fine for some reason.
I figured there may be a block in a pipe, as the water is quite dirty needs flushing, or an airlock.
Seems no sign of water in oil or anything like that.
all the pipes from raidiator etc warm normally.
There are no leaks of water as far as i can see.
May be a radiator problem?
I want to eliminate the possible dirty water factor by flushing -
So my question is, how to flush? I cannot locate any drain plug so would it be a case of removing pipes?
I'm getting a Haynes manual but since I don't have it thought to ask here. . .
Any other ideas tips or oddities about Cinquecento Sporting Abarth 1.1 1995 that might explain this kind off thing, gratefully received!
