Water Mist Kits for Intercoolers.
Wolverhampton
I watched a video yesterday about spraying the intercooler with water to reduce the temperature of the air before it enters the engine.
A gain of a few horse power is supposedly the result. A bit like the extra umph we all feel on a cold morning.
Has anyone actually tried this on a road car?
I have an old water pump from our caravan that produces about 40psi and because I have nothing better to do I thought I might test the theory and try making a simple water misting kit for my intercooler to see if it actually does make a difference. Activated by myself 10 seconds before I plant my foot on the accelerator it should cool the intercooler sufficiantly to make a difference.
So is it worth my time and effort or will I acheive nothing more than a wet intercooler?
There are also water to air intercoolers.
I have seen lots of different setups where they are putting Ice into the systems tank.
Lewey is trying one such kit in his brilliant Uno Turbo seen here;
https://www.fiatforum.com/uno/245531-1368cc-16v-fire-turbo-t-jet-uno-conversion.html
They're good (with ice or CO2 -- "dry ice") for drag strips and where they are packaging issues. Stock Scubbies tend to come with them, but just about everyone bins the "interwarmers" and replaces with air to air intercoolers when going for more performance. There seem to be issues with the quality/price/noise of the pumps available.
While searching for some spray nozzles I stumbled accross this intercooler water spray kit for £40
http://www.ebay.co.uk/itm/250882151295
And here is it working.
[ame="http://s296.photobucket.com/albums/mm189/Shadeyman67/?action=view&current=IntercoolerWaterSpray.mp4"]IntercoolerWaterSpray.mp4 video by Shadeyman67 - Photobucket@@AMEPARAM@@http://vid296.photobucket.com/player.swf?file=http://vid296.photobucket.com/albums/mm189/Shadeyman67/IntercoolerWaterSpray.mp4@@AMEPARAM@@vid296@@AMEPARAM@@296@@AMEPARAM@@mm189/Shadeyman67/IntercoolerWaterSpray@@AMEPARAM@@mp4[/ame]
thats not a bad result for 40 quid worth it if there are some proven gains
There's deffinately a gain, we're just not sure how big. He guessed it was between 5% and 10% as he had similar results from a cheap tuning box on the low setting he once had installed.
He's going to do a few timed runs with and without the system as he's sure it will show an improvement.
Here's one of the websites he used when setting up the system
In road cars, intercoolers act far more often as heat sinks rather than as radiators. Instead of thinking of an intercooler as being like the engine coolant radiator at the front of the car, it's far better to think of it as being like a heatsink inside a big sound system power amplifier. If an electric fan cools the amplifier heatsink, you're even closer to the mark.
Most of the time in a turbo road car there's no boost occurring. In fact, even when you're driving hard - say through the hills on a big fang - by the time you take into account braking times, gear-change times, trailing throttle and so on, the 'on-full-boost' time is still likely to be less than fifty percent. In normal highway or urban driving, the 'on-full-boost' time is likely to be something less than 5 per cent!
So the intercooler temperature (note: not the intake air temp, but the temp of the intercooler itself) is fairly close to ambient most of the time. You put your boot into it for a typical quick spurt, and the temperature of the air coming out of the turbo compressor rockets from (say) 40 degrees C to 100 degrees C. However, after it's passed through the intercooler, this air temp has dropped to (say) 55 degrees. Where's all the heat gone? Traditionalists would say that it's been transferred to the atmosphere through the intercooler (and some of it will have done just that) but for the most part, it's been put into the heatsink that's the intercooler. The temperature of the alloy fins and tubes and end tanks will have risen a bit, because the heat's been stored in it. Just like in the amplifier heat sink. Then, over the next minute or so of no boost, that heat will be transferred from the intercooler heatsink to both the outside air - and also to the intake air going into the engine.
http://autospeed.com.au/cms/article.html?&A=0527
Activating the system 10 or so seconds before its needed was key to getting the best from it due to this "heat sink" effect road car intercoolers have. The lower the start temp of the intercooler the better.
