Technical water loss mystery
andy majorca
:confused: got 8 year old seicento doesnt overheat or loss of oil but uses water about a pint every 200 miles,there is no smoke or loss of power where is the f"""""king water going not got any leaks from pipes etc
rallycinq
Autotest Special
Lake District....Moist
Water pump, its behind the cam cover so you can't see it. Get a pressure test done, then you'll find where its going. Also get the cap tested in case its given up the ghost.
You do remember to bleed it each time you fill it up.
Italian Coke Can
Mine was using a L of water every tank of petrol. No smoke, no power loss, good idle, clean(ish) oil.
Changed the HG and it was all good.
Nottingham
Head gaskets get neglected just like valve stem seals do.
Every one maybe presumes or hopes it's already been done by someone else or these things last forever.;)
phill151
try the heater valve on the matrix behind the padding at back of engine mines leaking from there runs fine just got to top it up every two weeks (300 miles)
phill
