Technical water inside cabin passenger side
Sauraabh2177
friends since past few days the floor mat of my grande punto is continuously wet today i found the reason after removing the panel of passenger side front .
water is dripping from there continuously i am attaching some pictures and help would be appreciated before any short circuit etc happens due to this.
Heater matrix leaking,temp fix is to connect the two heater pipes together that go throu the fire wall above gearbox.it will stop the leak till you get time to replace it,but the heater won't blow hot.
please clarify as to does heater matrix is faulty and needs replacement or there is problem with pipes which needs replacement
Hard to say from the pictures, you're the best to tell us from on-site ;-)
BRs, Bernie
If someone here helped You fix -or better- understand your issue, hit the thanks icon @ bottom right corner, it's free and makes us feel helpy ;-)
problem resolved.
the drain pipe for water exit was blocked.
it took 15 minutes of jobs thanks for reply and help.
