Technical water drain plug/fiat ducato
Does anybody know where the drain plug is, fuel/water warning light is on
As with all questions on the forum, to get an accurate answer the Model & year of manufacture of the Ducato & which engine is fitted needs to be stated. If it is an 02-06 244 Ducato then the water sensor on the bottom of the filter has to be disconnected & unscrewed to drain the water. As corkman has stated I think the new X250 uses the plastic filter, but I would immediately replace the filter itself if it has water in it regardless of which model Ducato it is.
