Water as fuel
Water as fuel
still don't trust it, the volts were high before the water began absorbing.
also wires all over the place, not the best way to stop none belivers.
if they showed a closed system that would be an improvment.
and plugeed things indervidually
Of course we'll always have the "its impossible" brigade chanting their "its against the law of physics" crap but they said the same thing when the wheel was invented and when we solved the problems of flight.
To be honest the "it can't be done" bridage bore me and I find the "oil companies wouldn't do that" idiots just as irrelevant.
Thank god for the Enstein's and Hawking's amongst, if it wasn't for them pushing the boundaries we'd all still be dwelling in caves.
Water will be used as a fuel by everyone one day, I hope I'm around to see it happen.
Whilst this is certainly true at present, scientist now claim they have discovered a microbial enzyme which acts as a catalyst (as enzymes do), lowering the activation energy needed to break the H-O bonds. Just cannot for the life of me remember where I read this, and it was only yesterday :bang:
It's not the process of photosynthesis involving cobalt ? Or the recently discovered method using manganese / Bimessite and sunlight (to put it simply)? (which has existed in nature since time began?)
Ah, you're referring to artificial photosynthesis. I came across this at uni last year when doing some research. It is very interesting and I imagine that it is related to the enzymatic technique I mentioned earlier. However, if I've got my head around it correctly, the use of cobalt oxide nanocrystals provide the catalyst in place of enzymes, but the latest research uses actual enzymes. I'm not sure what the benifits of this are, but I assume they are more efficient than the CO3O4 and costs may well be lower.
I think it's going to be an interesting 10-15 years or so seeing how these things develop (if they develop at all)
One method of green hydrogen generation I read about somewhere that I thought sounded like a good idea was using aluminium and water with a little sodium hydroxide (lye) added to it.
The lye breaks down the natural oxide layer on the aluminium so that the water can react with the aluminium to make hydrogen and aluminium oxide. The H² can be used to power a fuel cell or engine and the aluminium oxide can recovered after the reaction and returned to the smelters for smelting back into metallic aluminium to be reused. The power source that most aluminium smelters use is hydro-electric so there are virtually no carbon emissions for the entire cycle.
I'll try and find the link to the original article as it had some interesting stuff on H² power.
Dated May 2011
http://www.sciencedaily.com/releases/2011/05/110516102331.htm
One of those things you read, think 'wow', hopefully we'll see some changes for the better & then forget it as nothing seems to move on.
Of course, as long as some people can continue making shedloads of cash out of burning fossil fuels, I suspect this tech will be kept in the developmental stages.
i have quite a large HHO generator, but TBF when you use it on a car.. the power it draws from the alternator cancels out what you gain from using the HHO gas.
i have done quite a few experiments with running engines on HHO and yes the engine runs fine on the gas but you need gret whacking batteries to start it off and a engine just connected to a alternator to keep the batteries charged.
you end up using all the engines power to make electric to break down water into HHO gas to run the engine on.
i did however manage to get a 50cc 4 stroke engine+alternator makeing enough gas to power its self for 4 and a bit hours non stop. where as if i was to use the petrol tank the engine came with it only lasted almost 1 and a half hours running with the same load (the HHO cell connected draining power, but not putting any of the gas in the air intake of the engine)
i must admit that if i can do a thing like that with the resources i have.. just imagine what a multi-million pound company could do...
makes you wonder what is actualy out there being hidden..
