Washer jets problem - what do i need?
S
Stu
When i squirt the rear washer jet, the pressure is pathetic! plus water comes out the rear when i squirt the front! what new bit do i need?
Cheers Lads
Stu
Common fault Stu...check the repair guide..shows you how to fix it and has pics as well
i know the hose is connected on the rear as it came of recently but ive had poor pressure affecting the rear spray as it only goes about 6 inches up the window, do you reckon there will be a valve that needs replacing as the front ones are fine?!
STu
Its not great at the best of times...makes sure all the hoses are clear...pull out the little pump from the washer tank and check if the inlet pipe is not partially blocked
Also check the non return valve which is behind the cover at the bulkhead behind the battery (may help to remove the main fusebox cover). If its blocked, you can get replacements, or you can replace with a straight piece of tubing, but it will take longer for water to reach the rear jet..
Owen.
1
646
Dark Lurker
K
2
1K
Dark Lurker
T
5
623
K
G
8
357
K
W
914
wakka
W
