Warranty
Warranty
M
Matt Bowden
Guys, just a bit of re-assurance required !
Have a problem at the moment with the 'Idlers' that run on the Cambelt, they are making a shocking noise and are believed to be quite expensive. However I have three months left on my Hallmark Warranty, are you aware if this is covered ?? Or if the Cambelt went for eg, would this be covered ????
Thanks a lot
m
most warranties dont cover work which is classed as routine maintenence. i.e. if you are due a cambelt change then it wont be covered because the belts are usually changed with the tensioners as well. if it has only done about 40,000 miles then claim fast becuase belts are not till 72,000.
riclemus
S
7
218
M
T
9
245
Richard
R
C
2
173
craig
C
K
1
184
B
