General Warning Triangle
Hi All
Peculiar one this evening, I had the yellow warning triangle come on this evening, thought nothing of it and parked up, switched the car off and back on and it was gone. I took the car for a run round the block and still no warning light. I put the car in reverse to park it and had the warning triangle had come back on and also my stop start light on the radio panel had also come on with the message "stop start disconnected" with no option to reconnect the stop start. I put the car in the space and switched it off and back on and warning light disappeared. Obviously a stop start fault but any ideas as to why?
Hi All
have a read of the FAQ electrical thread at top of GP section.., ;)
Charlie
Hi All
Hi Jack
Did you figure this out? I have the exact same problem. My triangle light is on along with the S next to the hazards. I have never used the S/S.
Help would be appreciated!
Hi Jack
Hi. Same advice really..
Read the FAQs
Disconnect battery overnight..
See if it resets..
Then read fault codes.
Charlie
I had the same problem first it was disappearing when i off the car and then it was there all the time and spent fortune trying to get rid of it but it wasn't diagnosed correctly i changed the battery and the brake pedal switch and the accumulator and the disc speed clutch on my car then it was too late and i had to replace the whole unit. you need to check your hydrulic pump pressure value by the ecu scanner and the mega hydrulic if there is any fluid leakage.
you need to move quickly before you get it big like me.
