Billybilly
I keep getting a warning on my dash saying insufficient engine oil pressure.my car is 2013 punto 1.2 pop.help please
- Model
- Punto
- Year
- 2013
- Mileage
- 95500
Comes on random when drivingHi and welcome,
When does it come on..?
LOW revs.. Cornering..![]()
Oil level is spot onObviously get the oil level checked first and foremost on level ground, as a priority
Ive found the sensor its next to the oil filter ill get one tomorrow thanksIt's number 7 in this pic, as lng as I've got your car correct
10301/60 - DIP STICK, CAP, TRANSMITTER AND PRESSURE ROD
FIAT PUNTO MY 2013 (2013-....)eper.fiatforum.com
Now the oilcan red light is coming on intermittentlyIt's number 7 in this pic, as lng as I've got your car correct
Last septemberWhen was oil and filter last changed?
Ok, so probably unrelated..Last september
These oil sensors are manufactured down to a price and are not unknown to fail giving similar symptoms to yours. Is there any sign of oil around it which is definitely coming from it? Often they leak when failing. Scanning for stored codes is always a good idea, but in this case, I think the ECU will be taking the signal from the sensor to produce a code so may not be reliable. Checking for a loose connection or damage to the wire followed by replacing the sensor is probably not a bad place to start. If the problem persists then I'd be checking the actual oil pressure by screwing a pressure gauge into the hole the sensor fits in - or any other accessible place you can gain access to the oil galleries - and seeing what the actual pressure is with the engine running.Now the oilcan red light is coming on intermittently
Good question.Are you saying you've now replaced the oil pressure sensor and now you've got a oilcan light intermittently ?
changed the oil and filter a.nd air filter and spark plugs and the sensor and light and warning is still on.the oil fillercap was removed with engine running and theres no oil insideGood question.
Not a joke you can normally see oil on the rockersNot sure if this is a joke or badly worded ?
You won't see oil per se upstairs in the rocker box (where the oil fillercap usually is)
You've checked level with the dipstick right ?
