Warning Lights
  • Thread starter Stuart
  • Start date
  • Replies 4
  • Views 214
Warning Lights
S
Stuart
Once again I find I need advice from the people that know Brava's!
My 1996P Brava 1581 16V SX runs well, apart from being a little heavy on petrol.
I've just noticed that the Hazard warning light switch is always lit. I can't recall if it's always been so since buying the car or if it's a recent thing.
Does it being lit all the time denote a problem with something, or is it quite normal?
The Hazards work OK when you turn them on, and the warning light flashes on/off as it should when Hazards are used.
Hazard warning light also goes out when ignition switch is off, but stays on as soon as ignition is turned on.
All other warning lights function properly, as does all other electrics (radio/cassette, sunroof etc).
There are no after market additions to the electrics fitted either.
Hope that gives you enough info' to diagnose the problem (assuming there is one).
Many thanks for any help you can give.
Re Warning Light
Thanks for your replies.
Special thanks to "Grandad"....I was hoping that was the case, so until I get some indication that all isn't well I'll keep going.
Re: Re Warning Light
Yup it is always lit!
Ghengis Khan, www.babarmalik.com
P
2
638
Dark Lurker
J
831
J
S
2
700
Dark Lurker
J
1
878
Dark Lurker
