Technical  warning lights
eldiabolo
hi hav just developed a new problem with my car, when I turn off the ignition a get a number of warning lights that either come on or stay on random ones but mostly handbrake, over temp and oil!
Any ideas?
assuming you havent been messing with anything
try disconnecting the negative battery lead for 10 minutes to see if the bsi resets itself
if you have the original fiat radio it shouldnt need the code but if it does we can supply it for a couple of nicker on here
you dont say year model etc but there is a possibility that bsi has got water ingress whicjh as mrt would say is bard
and welcome to the forum eldiabolo:)
whats the bsi?
oh and it's an x plate 1200 2b 2 door
thanks disconnecting battery seems to have sorted it, we'll see over the next few days
Sounds like the common but un common bsi /dash crashing on shutdown
Come again? How can it be both common and uncommon?
bsi?=
beef
sausages
an orse innit:D
or computer brain behind fuse box :)
Why is it only people in the Punto section who don't refer to it as the Body Computer like everyone else does, and knows this particular ECU as :confused:
