Technical  Warning light
Markandjulie630
Hi all have a injector warning light which comes on every time I turn key to position 2 (red battery light position) for a fixed 4-5 second time period always the same on my ducato 2.8 jtd 2001.
I guess it's one of the sensors giving a funny read but I don't know why always 4-5 seconds before going off and starting and running ok.has anyone had this before cheer mark
Haven't seen a 230 in a long time but in the handbook i believe it will tell you that turning the key to MAR the light should come on and go off after a few seconds thats normal. If it comes on while driving it indicates a problem with injection.
You're other thread said you were having problems this thread says it starts and is running ok :confused:
Hi thanks for that ,the warning light used to come on/off after a second just as a standard check but now a fixed five second light would appear to indicate a sensor issue???? .the starting seems better the faster the crank over is so will normally start. The only other thing of note is the immobiliser has a mind of its own normally more problem first thing cheers mark
Sounds like low pressure, if its turning over at 250+ rpm and still taking more than a couple of seconds to start then do a leak off test to check for leaky injector
