With winter coming in, you'd think that the vents only blowing warm air isn't such a bad thing! But it's still annoying me. It's only started recently....
I know having the climate control on the lowest standard setting of 16 degrees isn't meant to be cold, maybe just about cool at best especially with the outside temperatures, but it seems to be blowing warm all the time. if i turn it up, it get hotter, which is great, but I can 100% say the temperature it blows at when it's on 16 degrees is warmer than it was during the Summer!
I also think the gas canister (or whatever it is) needs replacing as when I press the air con button (snowflake) the air isn't as cold as it used to be (I know I sound like an old fart moaning about how everything used to be!).
Could the two be linked? And how much does it cost to get the air con gas/liquid stuff changed?
