V vandisian New member Joined Dec 16, 2005 Messages 207 Points 49 Location Arbroath Feb 7, 2006 #1 what tools are required to change these?
dave ****** Parked in the garage Written 10+ guides Joined Aug 10, 2003 Messages 125,210 Points 24,472 Location Essex/Suffolk border Feb 7, 2006 #2 fingers, maybe a bent screwdriver or long nose pliers you need valve spring compresser first though, are you doing them with or without removing head
B Badger_Benji Member Joined Dec 19, 2005 Messages 417 Points 69 Location Lincoln Feb 7, 2006 #3 The proper tool to use is a valve spring compressor, then remove the collet, withdraw valve, and then replace seal, you will probably need a long nose pair of pliers to remove the old seals with. Be careful pushing in the new seals.
OP OP V vandisian New member Joined Dec 16, 2005 Messages 207 Points 49 Location Arbroath Feb 7, 2006 #4 cheers im taking the head off, got a patched up gasket on it which is working a treat but wont tempt fate so getting a set thanks for the help
