re: Valeo clutch & Gearbox replacement
The black graphite grease you have is probably Molybdenum Disulphide grease, which is suitable for most CV joints at the hub end of the driveshaft. For the star joint in you pictures (located at the gearbox end of the driveshaft) Fiat specify Petronas Tutela MRM ZERO grease, which is a yellow/brown colour as you describe. I think it's a lithium soap based grease.
If you haven't lost or contaminated any of the existing grease, then you could just reassemble the joint as it is. If any has been lost or contaminated, then you will need to wash out the joint and refill it with 85 grams of MRM ZERO. Unfortunately, as I found out a few years ago, MRM ZERO is very difficult to locate.
When it comes to refitting later on, any advice/tips on refilling the boots with grease – I’ve got a tub of graphite? grease in the garage which says it’s suitable for CV joints, but looks kind of black/grey in colour while what’s already in looks more yellowy/brownie coloured?
