Urgent! HU HELP!!
Urgent! HU HELP!!
lanarkshire
Ahhhhh help!!! dvd player installed, lcd working great all seems fine but!
dvds and cds wont play on install only on front speakers, but radio and others will play on install!!
i really dont have a clue what to do !
any advice please!!
xxx
luke1985 said:
try completely unplugging the stereo for an hour or so then plug it back in. My new sony one sometimes gets its knickers in a twist and i have to remind it that it has to work to be fed ;)
tried every thing, its no use, its the wierdest thing ever, for sum reason my red and yellow cables are soldered together?? is this normal?? ne way the amp was staying on and the hu wasnt workin at all today, then the amp was sort of pulsing. cinq is in the body shop again so they gonna try n fix it. xxx
The red and yellow wires being soldered together make the headunit be switched on all the time, so you have to power it off manually (ie press the power button for 3 seconds or whatever)... Nothing too dodgy about it, most cars with no accessory switch on their ignition barrel do this (but usually just move a bullet connector rather than actually soldering it).
Sounds like a faulty Headunit to me now - keeping amps on and not working
we tired to re wire me old head unit back up, and it done the same, im really worried bout what has happened. there is power going to it but not doin ne fin, strange xxx
If the boys at the bodyshop are any good with a soldering iron, get them to re-wire you a new ISO plug to the car.
Run a seperate feed from the battery with inline fuse and connect it to the yellow wire on the ISO, and also run a new ground wire to the black wire in the ISO (and mount it to a new ground point somewhere under the dash).
If you're using lots of power i would use this as an opportunity to upgrade the thickness of cable too :)
TBH, theres not alot in the wiring for it to go wrong. Theres only 4 wires (5 if you have power areal) that will ever be connected up on the power side, and 8 wires on the speaker side. If you're joining the red wire to the yellow wire, effectively you're only need to connect 3 wires to the power plug of the ISO.
ISO Power plug wires:
*Yellow = Continuous power feed
Red = Ignition power feed (disabled by joining with yellow wire)
*Black = Ground
Blue = Power Areal
Orange/White (IIRC) = Illumination (dont really need to connect up either)
So all you need to connect to get your headunit to work is the 2 wires with a * provided your red and yellow wires are spliced together :)
If its been metered and power is coming to the yellow terminal, check the join to the red wire. For your headunit to work with the engine off, the yellow and red wires MUST be joined together, and if the joint is dodgy etc, the headunit wont turn on as its expecting an ignition feed. By joining the 2 together, you're effectively supplying a constant ignition feed, so the headunit will work regardless of the cars ignition status.
Hope all thats clear :eek: But in short... Double check that the yellow and red wires are both supplying power at the **headunit end**, and the ground isnt bad :)
thanks, that does make alot of sense, it seemed really easy with just the red/yellow and black ad blue which is why i couldnt get my head round what was going wrong. will let you's know what the spark says on wed xxx
