Technical Upgrade Bulbs
Since fitting the bulbs i have been getting on coming cars flash their headlamps at me. I took some pics with headlamps on, dipped and main beam, omg they are really bright, i'll post some pics up later cause im off to bed having finished my last night shift :D
Philips 80 % brighter bulbs
Have you got the Headlight adjustment set on "0" if you have inadvertently adjusted the headlights up over then you will get flashed
There is no "0" option on the 1.9 MJET, just an up or down option (in the form of a headlight) (y)in the menu on the right hand side of the dashboard.
I have the philips bulbs and set to position 0 (which they should be under normal driving conditions) and I've not once had someone flash me.
Plus you can clearly see the very sharp beam cutoff straight across the horizontal span of the road, so you can pretty much anticipate whether you may be blinding someone.
