update on the super charger
donny lad
well after searching for 3 months ive found one a eaton m62 supercharger
in australia lol
eBay Link
all i need now is the money to buy it lol
***ANCHOR TAGS, GODAMMIT !! ;)***
whats the story on the marea with the supercharger does anybody know how thats coming along?
dunno mate hes never posted a reply lol
i feel hes using the wrong lower to as the 45 will never be able to make more than 200bhp where as the 62 is capable of about 250 bhp and has a clutch so it doesnt have to run all the time
yep lol it was where i was gunna run it lol a bit of a coincedence dont you think lol
i wasnt gunna do it cos of the power issue but now ive found a charger that will runn enough power i think its gunna be a goa lol
good stuff, could turn out to be a cheaper alternative to the turbo conversion, but then again you wont get the sound of the turbo and dump valve lol
wonder if it would work on a 1.2 ;)
For those with no sense of humour who always post the standard "just buy a bigger engined car" reply
I WAS ONLY JOKING WHEN I SAID THAT! :)
well heres the first run on the simulater
http://www.eatonperformance.com/superchargers/Simulator/Results.aspx
i reckon it could be run at about 80% efficiancey myself with a big enough intercooler
it must have timed out lol hang on ill do another one
this was done on a standed 2.o engine running 134bhp so the results will probably see about 190bhp on the hgt before mapping etc the guy from eaton reckons it will do 220bhp all day long but says if i wanted more power it would defonatly want a turbo aswell as the bigger supercharger simply wouldnt fit in the bay lol
i dont know how long the link will las so ill jot theresults down here:
162bhp@4100rpm and 233.51nm@ 6000rpm and the S/C ratio is 2.73 at 6000rpm
well the bugger sold it didnt he lol so i guess its time to start searching again lol
tis a shame but atleast ill defonatley have the cambelt done in time lol
can u get a turbo for a 1.6 or a charger or do u need a 2.0 and do u know a rough price on them
you can do anything to anything mate but as ive learnt it costs money lol
everything im doing is custom i dont know weather there is anything for the 1.6 but theres no off the shelf stuff for the hgt.
the charger im using is an eaton m62 with clutch off a toyota carrolla from australia it is used on other cars but the best come from australia as they have clutches, anybigger and they wont fit under the bonnet.
unless youre planning on spending about £3000 you might aswell buy nos or pay £2500 for a garage to fit a 20vt lump from a coupe turbo.
you can fit a m45 but for what it would cost you would be better off having the coupe engine as the gains from charging the 1.6 wouldnt be much more than the std power of a hgt as the charger its self is capable of more than 190bhp and at that power you would need to change all your internals as it would raise the compresion ratio to high and melt a piston lol
what i will say is it is one steep learning curve and it can get trickey but its worth every penny when its all done cos knowing youve got say the fastest 1.6 or fastest 2.0 is better than you can imagine lol
if you comletely nuts you could always stick a alfa v6 from a gta in it lol
right i have just found out some more info lol
i am using a technique called flow charginging,
tis is :
air filter, throttle body, charger, intercooler, inlet.
i will require a standed 20vt intercooler if anybody knows of one please.
also does anybody know of any good forged piston makes?
if i dont use a intercooler it would have to be chrger, throtle body, dump valve and inlet but that would be the unreliale way as it would put extra heat in the inlet charge and preasure against the throttle lol
plus the guy whos running off the alternater isnt going to make enough power at the charger to power it as it needs to be on its own belt with very sterdy brackets as its gunna have 50bhp running through it.
does anybody know if the 2.4 stilo throttle body is bigger than the hgt?
F
7K
F1-ANG
F
E
1K
E
C
636
ChrisKnottIns
C
