gholian
On the Fiat Uno the window sweeps on the outside of door. Rubber strip between door and window. The problem with these is the rubber shrinks over time leaving a gap at each end of the door. I have searched for old posts relating to this. Some say this causes more water to go down doors causing the door bottoms to rust faster.
On one post it says the Uno window sweeps are the same as used on the Cinquecento. Wonder could anyone confirm this. I think on the same post it also says it is possible to swap the ones on the inside of the door which don't shrink as badly with the one on the outside. I had a look on ebay Italy and I see one's for the Uno but it says they are for the inside of the door only. I was wondering could anyone confirm if the window sweeps on the inside of the door are the same as the ones on the outside. Looking for these for a two door Uno and would anyone know the part number for these.
Thanks.
Thanks.
