Technical  Uno turbo mk2 engine management system
Can I chip my engine management system from cutting out boost when boost is on max ?? Please help !?!!?
How can I do it will a normal engine management chipper be able to do it or will it have to be someone specific .
Has for as I know you can't chip the ecu from the Uno turbo its non playable unlike the Punto ecu if I am correct. If you have unplugged you overboost switch I suggest you reconnect it so you don't get overboost cut outs. And see what happens.
