Technical  Uno turbo mk2 engine cut off switch .
is it cutting the spark when you go over 0.7 bar? that would be the over boost switch that is located in the side of the plenum chamber.
you can just unplug it, but if you up the boost you MUST sort the fueling or you'll run lean and melt pistons :bang:
