Technical  Uno Start
Technical  Uno Start
stalker258
sum times it wont start then it does but wen its running it will get to say 30 in second n start spluttering then the next minute it will hit 40 in second no problem any1 no wot the problem is im baffled thanx peeps :confused:
Hi stalker258,
(y) Welcome to the forum
Please note that text talk is not acceptable on Fiat Forum :nono:.
:) With that aside, Please tell us a bit more about the Uno Start – Like is she a diesel? And any other symptoms?
Regards,
Louie Bee said:
Hi stalker258,
Regards,
its a little 1l petrol as for other symptons only sumtimes if u giv it big revs it will backfire in the exhuast :bang:
Same symptoms as this thread https://www.fiatforum.com/showthread.php?t=31937.
The Uno Start is a branding for “Base Model” and I think they are all fuel Injection. The 1108 engine is the same as the 999 more or less.
Do you know when the spark plugs, rotor arm and distributor cap were last replaced?
TBH I’m suspecting the distributor pickup sensor is on its way out. Where are you from? I have a known good distributor you could borrow. I’m in Manchester.
Kind Regards,
