Uconnect firmware 13.00.80.01
Uconnect Uconnect 5" firmware update: 13.00.80.01
No permission to download
Is this firmware something i can install on my radio? Fiat Doblo 2018. My device has "APPS" as last button. Update manager 9.1.0 is installed but it doesn´t work, i can not start Uconnect Live, if trying to update i get "Test failed. Error code P001".
Initial problem is that my phone connects over BT, but all incoming calls give "line busy" signal. I can call as well, but can not recieve calls.
Maybe update helps!?
Also, I wasn't able to go into engineering mode neither with RADIO + MEDIA + BROWSE nor with RADIO + BROWSE / ENTER, so is there another way to enter it?
Did you try with the ignition turned on?
I've got a similar issue as i've seen within this thread.
I have a Fiat 500L 2016 with a 5 inch uconnect radio - Fiat 312 VP2 ECE DAB
The radio starts up but then gets stuck on the fiat logo. The radio works however no buttons work apart from power, volume, mute and steering wheel volume and mute.
The usb port doesnt provide any power either.
I am unable to check the software version that is currently loaded on the radio (because of the above)
Would really appriciate assistance on this.
Best,
Henry
Hi, my unit is restarting nonstop I don't know what region or too much about it ( I'm in UK) but these are the screenshots .
I hope a software update, if I can make one , will sort it out. Thanks
Does anyone know, how to factory reset Uconnect 5. I would like to wipe my radio station list.
In radio settings "clear data" and "restore default settings" don`t work.
I have checked the engineering menu, but there is no reset option eider.
Hi, so we're in the process of purchasing a 2017 500e with the uconnect 5" with built in nav, so can we update that with the files here that LordMetro shared? Any help or guidance would be appreciated, it seems like there may not be any official way to do it anymore anyway.
Goede dag mensen,
Mijn naam is Kevin & ik ben nieuw op het forum. Toegegeven, ik heb geen Fiat maar mijn goede dame heeft een Fiat 500L Trekking uit 2014 met de 1.6 dieselmotor. Geweldige auto & ik moet toegeven dat het een leuke afwisseling maakt om van mijn gebruikelijke dagelijkse auto te rijden. Hoewel het technisch gezien neven zijn aangezien de mijne een Fiat aandrijflijn heeft. :D
Hoe dan ook, vergeef me dat ik erin spring, maar dit is de meest technische draad geweest die ik heb gezien met betrekking tot de hoofdeenheden in deze Fiats en het is behoorlijk verfrissend om te lezen. Ik hoop dat iemand misschien kan helpen met een probleem dat we hebben.
Sinds januari speelt de hoofdeenheid zich af. Het schakelt in en speelt de muziek af van het laatste radiostation waarop het is afgestemd, maar geen van de knoppen op het scherm verschijnt. Alles wat je ziet is het Fiat logo. Na een paar minuten start het systeem zichzelf opnieuw op en dit gaat keer op keer door. Het start nooit volledig op. Ik heb geprobeerd de batterij een paar uur los te koppelen en heb zelfs mijn toevlucht genomen tot het een heel weekend verwijderen van de zekering voor het systeem, maar het mocht niet baten. Ik denk dat ik deze thread al eerder tegenkwam en het updatebestand eruit haalde. Dat heb ik ook geprobeerd, maar er gebeurt eigenlijk niets als de USB-stick is aangesloten. Ik zie het licht op de stok een paar minuten knipperen alsof het wordt gelezen, maar dan stopt het. Ik vermoed dat er normaal gesproken enkele aanwijzingen op het scherm nodig zijn die worden verplaatst door op een knop te drukken, maar nogmaals, er komt niets op het scherm. Het systeem wordt nu meestal uitgeschakeld, omdat het nu vrijwel nutteloos is. Hij zal zichzelf af en toe aanzetten. Omdat ik in IT werk, lijkt dit allemaal kenmerkend voor een hardwarefout, maar ik vraag me af of iemand anders dit probleem heeft gehad en of ik iets kan doen om te proberen het systeem nieuw leven in te blazen, of dat ik naar een vervanger kijk.
Als ik naar een vervanger kijk, is het dan gewoon een gevalletje plug & play of moet de vervanger in de auto gehuwd worden? Of is het mogelijk om het systeem opnieuw te reflashen met de standaardafbeelding? Als iemand kan helpen zou ik zeer dankbaar zijn. Ze rijdt sinds januari zonder geluidssysteem en zou de Bluetooth-connectiviteit ook gebruiken om met haar bejaarde ouders te chatten op weg naar huis van haar werk, wat ze niet kan langer uiteraard.
Bedankt dat je de tijd hebt genomen om dit te lezen, en hopelijk kan iemand helpen.
Ik heb hetzelfde probleem, heb je een oplossing gevonden?
Hi every body, I want to upgrade my Fiat 500 Uconnect with this new firmware, but the system loop : update -> error code 127 -> replugged usb key -> update -> error 127.... Can we stop update process and return on the system. Have you an idea ?
Thanks for yourhelp.
Mathieu
Hey people,
Since one month, I have some DAB receiving problems. Does anyone have the same issues? Any fix?
cheers raffa
Mathieu
As far as I understood reading the forum and applying the updates on my 5 inches radio on 500L Trekking 2016, it is most likely to be suggested that you start with the lowest version, then update not jumping several versions, but increasing each version to the next one.
For example, I did 4 consecutive releases in few days, while driving for shopping and leisure... each one takes not much more than 30 minutes.
Doing so, with the engine running, I didn't let the battery decay.
Did the same also for the Navi, while the process took about 45-50 minutes, coming from a very old TomTom map to the newest.
I do declare, that I cannot feel any difference between the old firmwares and the new ones, but for sure they fixed something and perhaps the speed of the touchscreen is a little bit faster.
Thanks for your tips, bt my old version was 13.00.78.02, so i dont find other update....
Thanks.
Mathieu
Thanks.
Mathieu
Look at the upper right top of this page! ⬆️
There is an orange "Download" button, with which you get the latest firmware!
It took me weeks to understand that, and thanks to a kind user I got it!!! :)
i find th download button but i have an error during update;;; error 127...
Have you retried?
Do yourselfa favour: use a NEW and quality proven USB-key.
Format it in FAT32. No exFAT, nor NTFS.
Pure simple FAT32, whether it's bigger than 32GB or not, with Windows you can force the format with command line diskpart.
Hi
I have exactly the same question.
Did you receive an answer.
Hello,
i have a Fiat500X 2015.
My Navigation is loading and loading and loading (TomTom Original)
The Update from this Site here doesnt start.
Can anyone help me?
Thank you very much
Hello,
I´m looking for NAND+NOR flash backup from working unit. Can anybody help me ? Thank you.
