Hello there
As per my heading, my camper isn't a Fiat, its a Peugeot Boxer, but it is based on the Fiat Ducato X290
I have pulled the standard DAB radio and replaced it with a Fiat 250 VP2 ECE DAB NAV unit dated as 2017, so that I have a CD player, proper Bluetooth navigation etc
The net result is that I now have a flashing odometer, but I cannot complete a proxy alignment to clear it
During the proxy alignment, all areas update successfully, but OBDAlfa shows that the Entertainment Telematic Module (radio) fails as the ECU has detected that something isn't right
I have the following faults showing on the radio module:
B1562 - GPS Antenna open circuit
B1578 – AM/FM Antenna open circuit
B157A – DAB Antenna open circuit
I took this to mean that there is a short on one, or all of the antenna, so I unplugged everything apart from the main block, but the faults continue to return after clearing them
I borrowed the same radio from my brothers Ducato which works fine in his camper and it picked up the same error codes etc in my Boxer and again would not clear
If I reinstate the original radio, while AlfaOBD doesn't seem to see the radio, it does allow me to run a proxy alignment to clear the odometer flash
I've seen a mention somewhere else on this forum (cant find it now) that said to find the GPS tick box and enable it, but not sure how I do this
Any help would be appreciated
Trev
Trev
