Technical U1601 can bus circuit
pinkbecka
Hi after my engine management light coming on over a week ago last night my car failed to start so after calling rac he has been out and got my car started after but gave me the following error code. Does anyone know how i can fix this?
as the great zig says
try your car key on its own without being attached to any other jingly jangly
if this fails to sort the issue get the earth lead on the ecu under the aircleaner checked out with a clean up and replace back
i dont recal there is a symbol on a mk2 for lock out
there is for mk2b ie big headlight grille in bonnet model 53 plate onwards
so i assume you have mk2 v reg to 03 plate with slitty headlights
you still need to take on board what i say though because fairy dust wont work:)
a few mk2 dash displays showing engine management light which would lead rac man pulling your chosen code:idea:
hi its a y reg fiat punto it does have a key lock light but it is not lit im taking it to the garage on monday can someone tell me what i should get them to check sorry for apearing a bit thick but im a woman who knows feck all about cars lol :worship:
i only have the blue key and yes it works it comes on and goes off
so whats the problem then
try turning key slower when starting your car or even turn key so dash lights on /fit your seatbelt /turn the starting motor
unles your key is a copy key then i cant see why you have a problem
maybe car failing to start is a red herring from an earlier stored code of u601
