Oilrag, you mentioned the Hankook tyres. Do you have the model number of them?oilrag said:Alfavan,
I can`t think of any other contemporary vehicle of the same weight, torque/power, that runs on such narrow tyres, and small wheels as the 2002 JTD Doblo.
Yes, I remember the VW bus.
Re The Doblo, I always thought one of its strengths is the simple cart sprung rear axle design.
IMHO,It was not just the 95/93S tyres that solved the wear problems, but also the higher pressures.
Here in Yorkshire you can get 95/93S tyres, but there seems to be little awareness of the difference.
The difference in improved wear, with the commercial range tyres, fitted to the Doblo was so huge that when our Diesel punto needed new tyres, I opted for Hankook * van* tyres rather than the original equipment " Energy saver" car tyres.
Again, these commercial vehicle tyres are proving that they will more than double the mileage obtained from the original tyres.
Ozzie1989 said:... have had to adjust my braking style dramatically
Niall_G said:So no more handbrake turns then ? Shame coz your were just getting the hang of combining a handbrake turn followed by a quick burn out.
PS. How are the tyres? :devil: :devil:
No, on the Doblo.oilrag said:Cheers Alfavan, I was never into ABS, but the 2002 Doblo JTD convinced me that I had to have it next time![]()
And now i have it on a new Punto multijet van... I dont need it again..............
Doblo, Do you mean the tyres on the 1.9 D Punto?
These are Hankook RA08 165/70R14C 89/87R
Ozzie, I presume with mytyres you have to pay another garage to fit the tyres which could then make them more expensive than Kwik fit etc.Ozzie1989 said:They are quite cheap, although http://www.mytyres.co.uk/start.htmlhttp://www.mytyres.co.uk I find is cheaper, plus they give you more info about the tyres. Black Circles don't give you weight and speed ratings of their tyres - no good if you have a Doblo then![]()
alrightdrive said:I Get 9.500 Out Of P3's Or Budgets Tyres Wear On Inside. Big Commom Problem With Dob's Tracking Is Spot On. Ho? Ho? According To Fiat It's An Acceptable Amount Of Wear. Nearly Every Taxi Driver In Bristol Will Tell You,
