Technical 2015 Doblo 1.3 multijet clutch slave cylinder broke again.
Steve gt
Established member
Chesterfield
Hi guys I’ve had this recurring problem with mi doblo , in three years of ownership this has happened three times, the clutch slave cylinder on the top of the gearbox has either snapped or pushed past the clutch arm . I had it towed to the garage but they can’t get to it for a few days to fully inspect it . They think it may be the arm is seized or bend and may have to remove the gearbox. Anyone had similar issues.
Thank Steve
Also if the box has to come out I’m thinking to fit a new clutch, it’s done 130000 miles.
Thank Steve
The rod on my slave cylinder snapped, I fitted a new one but couldn't get a pedal, tried different ways of bleeding the clutch. I couldn't get into reverse. I managed to get a metal cylinder with a metal rod and now it is fine.
The mechanic has fitted a new metal slave cylinder to mine rather than the plastic one , it’s working ok but really crunching into reverse . The clutch is worn causing more travel on the clutch arm so it’s going in for a new clutch fitting soon .
I´ve noticed that when I put in 1st or reverse standstill too fast the gear´s grinding. But when I wait a second before gearshift this does not happen. Any symptoms you´ve encountered in relation to this?
Mine was difficult to get into first and reverse , I noticed it got worse as it got hotter.
