The thing that irriates me most is that it stops and re-starts straight away. Why in those conditions does it just not turn off at all. Very annoying. But only those of us who have experienced it will know what we're talking about
Exactly. And the car knows the outside temp, so if it is that it should really know not to engage S/S at all.
My grandfather was a Major in the Royal Army Service Corps and an engineer and he used to say the same thing - turning your engine off and on uses more fuel than you save, for short periods.
This is probably less so with modern ECU controlled fuel injection systems where there is less of a spike in fuel usage as the engine starts, but there must come a point when it is not worth turning off.
I do believe I said "car", not dash or ECUno it doesn't, the dash knows the outside temp, not the engine control system. There is a difference.
Seems to me like a shortcoming of the 500's engine-management, whichever part(s) of the system are responsible.
So it would seem that if it is a cold day, we are best off shutting S/S down manually.
So how much fuel is actually saved by switching on and off the engine for 10 seconds? I'd say switching off and back on for that short a duration probably uses more fuel if anything! I would imagine there is a minimum duration under which has a nil or negative impact on fuel saving and I'd reckon that duration would be more then 9 or 10 seconds
Regarding fuel used to restart the engine, unless it's cold and on cold start cycle it doesn't use extra fuel to start it.
Indeed"car" refers to the unit as a whole though does it not![]()
IndeedI'm just saying -- the data is there, available to be utilised.
The 'car' does know the outside temp though - think about where the instrument pack gets the outside temp reading from - it's on the CAN bus, so available to any CAN device in the car. Climate control needs to know the outside temp, as well as the engine management (for the fine control that EU5 demands), amongst other things..
Ok, so maybe not in Pop trim, but it is there.
I myself am a coder and now a dev manager, though I confess I've not written any C in 10 years now. Java, Python, PHP, and plenty of RAD, sure, but not hard-core C. I suppose in the kind of real-time application we are talking about here, C is probably still being used, but the speicifcs are somewhat irrelevant IMHO.
The data is there, everything else is just mechanics of getting it to the S/S system.
But anyway, we are getting a little off-topic![]()
I've kept the S/S off on my Twinair to reduce engine wear during the first 2K miles, but have now put it back on. And there seems to be a problem:
S/S shuts the engine down properly most times, but then the engine starts back up almost immediately.
Any ideas what could be causing this?
Many thanks in advance!
Dont just tell them to search Point them in the right direction! even if its just a link to the advanced search option with a bit of a welcome wouldn't go amiss
https://www.fiatforum.com/search.php
What will help even more Do a search for them and post them a couple of links from the search result to their problem. Along with the search link so you help them in the short term get the info they need and in future they can help themselves (that sounds like an Oxfam campaign doesn't it
Yes, I read that thread -- didn't think there was an answer in there though
I'm still getting the "twitchy" S/S, even at ~11C. Come to think of it, I rented a 1.2 Lounge in Oct/Nov, and the S/S on that worked fine even in the cold snap we had back then which was ~0C.
So I don't think it's the outside temp, or not *just* thatMight have to contact my dealer and see if they know anything about this kind of problem...
So I don't think it's the outside temp, or not *just* that ...
On the Stop/Start course it was stressed that the battery must have had a full charge before going out, otherwise the Intelligent Battery Sensor cannot monitor the battery condition accurately.
If it believes that the battery is at a level where it cannot be trusted to restart again if stopped, the Stop/Start will not work and the engine will remain running.
Remember that modern batteries do not receive a deep-enough charge from the alternator to fully top them up. If it's not 100% charged before it's fitted to the car, it's lifespan is reduced.
Hmmm... that is interesting! Worth putting a charger on it overnight, do you think?
