Technical Twinair turbo / EML issue
What have you done to it?
I've put new brakes, wheel refurbishment and Michelin all weather tyres, roof tray, full service Inc coil packs... just need to get performance/ EML issue fixed
Oh and fully coated underside in Lanoguard rust protection and new rear shocks
I have so far replaced the clutch and DMF, new propshaft, new suspension all round, new Michelin cross climate tyres, new brakes, new under guard, installed a roof rack, replaced the stereo with the new uconnect 7 inch with apple car play and now I am in the process of replacing the lights to LHD versions. I do still have an issue with the clutch which I suspect is a faulty DMF fitted, so it is going back in a few days for that. Also I have done a full service including coil packs:) I will probably change the exhaust before I go too if I can source one!
I had exhaust made.
Did you change the clutch yourself?
I'd never considered swapping fog lamp position....is there a converter available?
You will need to buy LHD lenses for the existing lights so that they are the other way around and then swap the wires over. The wiring loom on one side will not stretch to the other side so you will need an extension cable to make it reach. The alternative is to leave the fog/ reverse lights where they are but you will need to add another fog light externally to the other side.
I don't have experience with a FIAT but I did export a VW Golf (UK reg but happened to be LHD) to SK fairly recently. If you intend to register it locally (SK authorities really didn't want to consider a RHD) the most critical issue (for them) was to have a certificate of originality from FIAT in the country it was registered. This, apparently, gives the local authority that confidence that it was built to an approved standard... (this was more than slightly exasperating - like there were companies building knock-off Golfs...). Mine was a greater challenge since the car was sold and registered in Italy, so my certificate had to be obtained from VW Italia... Long story short it all got sorted.
What I really wanted to say the other thing that is quite useful is to have a LHD (driver's) door mirror which will give you the enhanced wide angle view. On the VW this was straightforward as it already had it (being LHD) which was a pain when driving in the UK.
What colour is your car?
Mine is Tuscany green...now with dark bronze alloys
Tuscany green here too:)
So diagnosis agreed by local garage... wastegate is toast.
A brand new not reconditioned full turbo from Mitsubishi is currently being fitted along with new oil feed and return pipes. Apparently an oil & filter change is necessary to gain guarantee. Looking forward to some performance gain...it was the slowest thing ever.....as it effectively had no turbo boost
