Well obviously in terms of BHP it's not going to compete. But in terms of economy it should be pretty darn good.
I think we have just gone full circle, lol. I hope that the first owner to post on here can redress the balance.
It's just so hard to drive a petrol turbocharged car economically.
We would hope its economy would be good. However, I believe the 500 isn't a really lightweight car. If I'm correct, asking a 900cc engine to produce great economy might not be so easy. It would have to be worked harder to make the same progess as the 1.2.
I could be wrong here, but it seems logical to me.
Yes but there is also a .9 normally aspirated engine.I dont think you can compare the two engines at all because the 1.2 is Nautrally Aspirated while the 0.9 is a turbocharged engine.
But - and here it is - I'VE had the car for the past 4 days. Stuck the thing in ECO, changed up when the indicator said (which was strange - coz it sounded like the engine was under pressure, but it pulled ok anyway) and driven it like a granny.
The result? 62mpg. If I'd driven the diesel that way I reckon I would have got a bit more (but not much) and I know that this is still not close to the official figures, but a couple of things are clear -
Drive it like it is meant to be driven - and I intend to from now on - you get competent mpg (but not world beating) but an engine that is characterful, willing and brings a smile to your face whenever you press the pedal - and in a way that no diesel will ever come close.
OR - drive it like every last drop was your last, and you will get as close as you can to some of the most efficient diesel engines on the market right now. And it has only 500 miles under the belt....
Can't fault the car.
500 miles in....
Mostly the wife driving (it's her car) - but if I threaten her enough, she hands over the keys... I think I'm in a good position to comment on how the car is performing - we traded in a 1.2 Grande Punto for the TwinAir, and I drive a 1.5 dci Megane - so I can make reasonable judgements on how it compares to a small(ish) petrol engine and an equivalent small diesel. I'm using the mpg readout on the car only, and I know that is not 100% accurate - but my experience tells me it will not be far wrong.
I need to state, first, that I am Fiat 'mad'. A 127, 2 Unos, a Tipo (great car, ahead of its time), a Stilo, 2 Puntos and I know, before I die, that I WILL buy a Fiat Coupe! I've never driven the 1.2 in a 500, BUT in the Grande Punto it was...how can I say this politely...underwhelming. Flat, slow and - over 2 years - average 36mpg. To be fair, not that bad for inner city driving - but the diesel would get 45ish at least on the same route, but with much more power and flexibility.
The TwinAir, in comparison with the 1.2 in the Punto, is a beast. It growls from the off, pulls like a train - easily as much as the diesel - and has 10 times the character. On the downside, because it wants you to wring its neck, you hold onto the gears longer than you know you should...
This week, it dawned on me why the TwinAir was so good. After 400 miles or so with mixed driving - commuting, stop start, the odd motorway sprint - the mpg was 42ish. Not brilliant, I know - but about 6mpg more than the 1.2 Punto would have got, and only 3 or 4 mpg less that the (admittedly heavier) Megane would have done.
I've been reading this thread from the start, and one question has popped into my head;
I may be way off the mark here as I have no experience of turbo engined cars (but I am an engineer of sorts), how does the turbo react if the car stops after driving on boost in its "start-stop" process when I thought the engine should be allowed to tick-over for around three minutes before shutting down?
Perhaps I have not been clear in my wording but hopefully someone can answer this for me.
My friend has his TwinAir delivered on 1st March, I've been promised a drive.
Tony.
IIRC this was discussed when the start stop was made standard on the multijet- I think the general consensus was that with a relatively low stress engine using modern oils oil breakdown in a hot turbo at rest is not an issue.
