Are you beginning to have problems selection reverse gear when stationary. You might be getting early signs of a dual mass flywheel failure, if this is the case do a clutch replacement at the same time and should cost £800 to £1000 estimated
Hello Timmy
The car goes into reverse perfectly the car only jerks when at very low speed and if you accelerate quickly it doesn’t jerk at all
When cruising if you lift your foot off the accelerator and put it back on there is a small judder
The clutch works fine in all gears
