Re: Re: Turning the Clock back......
Paul,
If yours is the same as mine it has the AD 182H head unit.
That's the one before the head unit with the volume control where mine has an eject button.
If it's the other AD 182L let me know and i'll look that one up for you.
Anyway press the Button with the clock on it until the colon between the hours and minutes stops flashing and "M1" or "M2" appears on the display according to the display mode selected. (can you tell i'm reading this from a book. lol)
Set the hours and minutes as follows.
(Keys 4,5,6 and 7 on the cd changer)
Press key "1"(4)to decrease the hours
Press key "2"(5)to increase the hours
Press key "3"(6)to decrease the minutes
Press key "4"(7)to increase the minutes
Short sharp presses will increase/decrease the hours/minutes by one unit each time.
Keeping the keys pressed will change the hours/minutes more quickly.
Once the right time has been set, press the "clock" key again briefly to start the clock at zero seconds.
the colon seperating the hours and minutes will start flashing and "M1" or "M2" will disapear from the display.
Hope this helps mate.
Rab.
"If at first you don't succeed lower your standards".
