Yes, but we started out making a rough and ready estimate of the compression ratio of your engine with 2 x 1.9mm head gaskets and an additional 4-5cc of combustion chamber volume. We now know the chamber is bigger than 22cc and your method is less rough and ready than my initial rule of thumb.
Using the new formula that implies:
Volume of 35.3 cc less the original gasket at 5.9cc makes 29.9 without a gasket. Add 2 x 1.9mm gaskets at 7.5cc each gives 44.9cc plus 4.5cc for the chamber enlargement makes 49.4cc.
310.5 + 49.4 divided by 49.5 gives a ratio of 7.3:1 Makes me wonder if you can afford to lose one of the 1.9mm gaskets?
Following this example one gasket would give 8.4:1
