Tuning  Tuning a Doblo?
JoshRobo87
Good evening new member from Leeds, West Yorkshire. I own a 57 plate Doblo 1.9JTD 8v in blue on 55000 miles.
The misses owns a 57 plate Panda 100hp in blue on 53000 miles.
I'm really interested in squeezing a little more torque out of the Doblo so any suggestion/ proven methods are welcomed, cheers
Well, if you can find someone who can remap the ECU, it should cost around 100 to 120 pounds.
Mine is a 59 plate 1.9 JTD with 120bhp, but I am having it mapped to 152bhp which is about the max.
My advice is new brakes & ensure the calipers & sliders are serviced (cleaned & greased) to ensure maximum effort and new shock absorbers as the extra 32bhp may not sound like much, but the effect is much the same as towing a heavy caravan around, then removing it, chucking out your passengers and going off like a stabbed rat :eek:
It will be more eager and willing as well as not feeling as though it is. Just take it gradual and get the feel of braking sooner (y)
Thanks for the info, when you say new do you just mean new stock parts or upgraded? I come from a ford background where on the Mondeo I had a decat, full cold air induction, remap and focus St brake set up, found info on doblos hard to come by, there seems to be no induction kit and I've found a decay but only for a mk 1, is the engine able accept 152 on standard parts?
I had a Saab 93 with a 1.9 JTD engine producing 180bhp from a Hirsch performance upgrade.
Granted it was a 16v engine, but it's the same block.
Try looking for Saab or Vauxhall performance parts. I have no doubt the engine will take the upgrade. I wouldn't bother with performance brakes as these were originally built as vans with tough suspension and powerful brakes to work whilst carrying a full load.
However, if you are experiencing brake fade, perhaps you are driving too fast for too long :D But seriously, try green stuff pads & cross drilled & grooved discs on the front.
Will Vauxhall and Saab parts fit a mk2? I know the new Vauxhall combo van is a mk3 just re-badged, what about Alpha parts? I'm lost in a sea of choices but don't wanna buy the wrong ones, cheers
I meant the engine parts such as K&N filter for instance. I would measure the original flat panel filter and see whats available.
As for brake pads & discs, any GOOD motor factor should be able to cross ref pads & discs to see whats available.
I'll have a look, but it may take me a week or two..... Thing is, the Doblo is a four stud, so Saab & Vauxhall discs wont fit. But the likes of Demon Tweaks should be able to source something.
