C'Circuit performance problem
hi, on starting my 55 panda mj ,( unused for a couple of weeks ) i revved it up to 3,8oo rpm a couple of times. eml light came on dash. i plugged in a multiscan ms300 & it showed code po226 . ? any ideas. cheers, steve.
hi, replacement battery fitted. blasted pedal area with compressed air, sprayed electric switch cleaner:idea:,left it overnight, started engine. eml light straight back on. every time i clear the code, start, light returns.at least 10 attempts.:bang: but at least its revving better.
thank you for any info/advice guys. steve
hi, thanks guys for the suggestions/info.i will have another look tomorrow if its not raining.
otherwise the mj is going to the rear of my driveway, and will look for another car.
( panda of course.)just as well ive got the wifes pug 107.
cheers guys.steve
hi, i checked the 6 pin plug on the accelerator pedal, and it seems fine. no corrosion or damp.. i tried the panda on various roads to see if the eml would reset itself. it didnt. on pulling away acceleration is poor. foot nearly to the floor.top speed 45mph in 5th.
got back home tried again to clear po226 code & eml. have now removed pedal
and collecting a used 1tommorow, just hope this will cure the problem.
any idea if a 1242 petrol & a 1248 diesel ( 169) use same accelerator pedal ? best regards, steve
