thanks alot really appreciate it:slayer:
First of all, my apologies! DON'T jack it on the lip that pokes downwards! I have done it before (and would do it again - in fact I've just done it again now to take the photos) but it DOES actually bend the lip slightly. What has happened is that someone has done that on my daughter's car in the past and what I first thought was a slight "flat" on that lip where the jacking symbol is presed into the sill as a downward-pointing triangle, is actually where the jack has bent the outer skin of the three bits of metal that form that seam on some previous occasion. Now that it's done, of course, there's no problem jacking it up on there again because the damage is already done!
Here's a photo of the "seam" I was talking about. Note the slightly flattened area towards the right hand side:
Here it is again with a trolley jack under it (note the bit of wood with the grain going ACROSS the seam)
Here's a close-up:
Note that slight bend in it? That was already there and I assumed it had been originally pressed that way by Fiat. it looks worse than it is, because of course, the seam is also digging into the the piece of wood.
Here's the factory-supplied jack under the back jacking point on the same side as the trolley jack:
and a close-up:
You'll see that the top has a cut-out in it to miss the flange. You could make up something out of hardwood to do the same and sit on top of the trolley jack if you were bothered about protecting the seam.
Lastly, a photo of the two jacks to give "context"
I don't know if you can make out the two downward-pointing triangles pressed into the sill to show where to jack, but they're there somewhere, just above the jacks! You could very easily replicate the top of the Fiat jack in my second photo by screwing a couple of blocks of wood on to the top of the first one to accommodate the flange poking downwards between them if you wanted.
